Facing system freeze last's up to 5 seconds
Sep 15, 2018
13
Specs:-
Core I 7 8700k
Asus Z370F gaming board
Corshair Vengence ddr4 2400mhz 8*2gb
Gtx 1070 G1 gaming
Seagate Barracuda 1tb + 2tb
Cooler master 212 led turbo
windows 10 pro 64 bit
My system is freezing for 5 to 7 seconds when I play games or watching movies even no other program is running which can cause system freeze first I thought its due to hdd usage which stayed at 50% but afterwards I saw an article to fix it by switching off some programs. I disable few programs now hdd stays idle on 5 to 15 % but freezing problem is not resolving.
Need Suggestion
if it is due to faulty board or processor or something else?
Do you have dual monitor setup? I run my PC through my TV when I want to watch things and sometimes if I don't disconnect the HDMI from the back of my TV the computer does this annoying freeze for about 1 second, when I am trying to game, so I pull out the HDMI and it works fine.
You can always run something like ZHPCleaner and check for malware.
No I am using LED monitor and no dual setup
this issue raises when I changed my board and processor from 7700k and h270f to 8700k and z370f
I reinstall my windows made new partitions when this problem occurs I also update bios but nothing is working
Yes after hardware change I ran old windows and update the new drivers on it just to secure my data after that I install fresh copy of windows by formatting and recreating partitions whole disk.
And yes I forget to mention i have 2*8gb 2400mhz corshair vengence ram in my board but one chip is running on speed of 2400mhz and other is on 2133mhz I tried to change slots turn on XMP but both rams are running on different clock speeds.
I took out 1 of my ram yesterday to check weather its due to different clock speeds seems that probably the case on 1 8gb stick my pc is running fine no freeze no lag since tomorrow. But 8gb is ram is not enough for me I need to put second one too.
So probably I need to decrease speed of 2400mhz ram to 2133mhz
Let me check this solution too so I will reply back if my pc stables.
