What that is telling you is that there is no recovery version on the device. If it had a factory image, or recovery stored on a
partition on the hard drive, then it's easy. However, it sounds like yours is telling you that there is no recovery information stored on a partition. So there is no way for it to do the work without the data needed.
Do you have a recovery CD or bootable Windows OS USB device? If so, those are what you would use to do this. If you don't have them then you will need to obtain a copy.
