Failed Drive in a RAID0 array, how do I get my computer running again?
HeadphonesOn
12
Alright, I've been trying to fix my computer for the past week, and have been running tests on it. I found that one of my drives failed a Seagate DOS test, and that it's pretty much done. I really don't care about the data inside the drives, I just want my computer working again, and I have no idea how to do that.
I know which drive is messed up, and it's the drive that was partitioned. I don't actually know which drive it is inside the computer though, because I don't know how to assemble, much less disassemble a computer. I don't know if I have to replace the drives, or if I can run the computer off the healthy HDD with the OS on it, or if I have to flash the BIOS. I literally have no clue where to begin. Memtest86 ran fine, 47 passes, if that helps.
I never set up the RAID0 array myself, since this comp was a hand me down from a friend who I am no longer in contact with. If anyone can give me any ways or lead me towards any places that might help me fix my comp it would be greatly appreciated.
You don't have to flash bios.
1 Go to bios, disable raid.
save and restart.
2 go to bios set boot prio to the dvd
3 insert windows dvd and boot with that and install windows on the drive you know is not broken -after formatting said drive. that is, if the broken one even gets detected.
Keep in mind, this will destroy all of your data, from both drives.
I don't have a windows OS disc or the any of the manufacturers discs that come with the computer. Also, I can't find anything that says "disable RAID" in the RAID interface [pressing CTRL I], only that I can reset the drives to Non-RAID or delete a Raid Drive. Is there like a repair disc I can buy or do I have to buy Windows all over again?
Alright, well looks like my real problem now is finding a windows disc or ISO. Well, I guess I'm just gonna throw away the bad drive, and leave only one in. Would I HAVE to set up a new RAID0 after getting the said disc, or would I be able to boot from a windows disc/usb and set it up on the working drive and get my computer to work from there?
This is really good since I think my bios is already in AHCI. Thank you for the help man, much appreciated 😀
