Failing Power Supply
thomasp13
6
Hello, I have been having power supply issues and would like to try to get some advice. I have a Corsair HX 750. I tried to start my computer this morning and nothing happens. Opened the case and there are no leds lit up. Tried a different outlet with no results. Tried original outlet and I get the mobo power led lit up so i try to start up the computer POST fails. I try another PSU and the computer starts up with no problems. The thing is this. This is my second HX 750 in less than 6 months and i am wondering if i just had some bad luck with them or there is something else i am not aware of that could be causing the problems.
first of all what are your full specs? also hx760 is a quality unit, since its not full modular you cant use another 24pin cable. at lest try another gpu one.is the fan spinning? if no luck try this http://www.corsair.com/en-us/blog/2011/may/testing-your-corsair-power-supply
