Going to try and keep this short. I bought a tablet off Wish. I know, I know. The tablet type was listed on other sites like Amazon and Newegg.
The tablet was supposed to be android 9, deca core, 10 g of ram, etc etc. It was spoofed to seem so. I used a few programs to do a variety of tests, filled up the memory and it crashed the program after 1.708 gigs, so I knew it was only a 2 gig ram tablet. I tried to install a program from the Play Store, wouldn't install as it wasn't compatible. So I went to the website to download a previous version. The Android 7, 5, and 4.4 versions wouldn't work. Only the Android 4 version would although the Android 4.4 version did install. So it seems to only have android 4 of some sort.
My Google account says the tablet is a Masstel Tab 10. However, the specs on that tablet do not add up to what I have found out on mine. 1280 is the resolution on Tab 10, I can go up to 1440. 1 gig of ram on Tab 10, I have at least 1.5 or 2. Nougat or Android 7 on Tab 10, I only have 4ish.
So my questions are a few. How do I get rid of the spoofing so I can get the real hardware to show up? (CPU-Z is fooled, Aida64 is fooled etc).
Secondly, I'd like to put the highest version of Android on it that I can. Would really like Android 9 if it would take advantage of the better memory usage etc. How can I do this?
Thank you in advance.
