Fall Guys 100% CPU but not using GPU (SOLVED)
stewuie
Great
Jul 4, 2023
157
6
85
Everytime i open up Fall Guys it's on 5 Fps and 100% CPU but on other games such as Valorant, Roblox Max Settings its alright? No 100% cpu consistently only on Fall Guys as it seems. Other games utilize both my cpu and gpu while fall guys seems to hog my cpu to 100% reaching temps from 83 degrees to 90 degrees.
What could be causing this?
Lutfij
Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. Include the BIOS version for your motherboard as well. As for your platform, was it always like this or did it crop up recently?
stewuie
Great
Jul 4, 2023
157
6
85
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
CPU: i5 10600
CPU cooler: Intel Stock
Motherboard: Prime H410M-E
Ram: 1x DDR4 HyperX Fury RGB
SSD/HDD : KINGSTON 240 GB with 1 TB HDD SEAGATE
GPU: GTX 1050 Ti (*note that i also reinstalled my gpu drivers with ddu didnt work*)
PSU: SilverStone 600W 80 Plus Rated White (*3 Years*)
Chassis: DarkFlash Pollux Case
OS: Windows 10
Monitor: 165 Hz Monitor
this doesnt occur to other games like Valorant, Roblox, Rocket League so i dont know what could be affecting this.
EDIT: It also used to ran at 60 fps or more back then.
D
Deleted member 2731765
Guest
Nothing wrong with your system. The CPU spike is caused due to Easy Anti-cheat/EAC software.
stewuie
Great
Jul 4, 2023
157
6
85
But what would explain the 5 fps?
And my cpu was constant 100% utilization to 80% back to 100% it didn't use my gpu it was chilling at around 45 degrees and not utilizing
OR is it possible that this game has a bug and thats the only logical reason i can come up to.
Because Valorant, Roblox, Rocket League, CSGO are all good so i think this is their game's problem ig?
