Fallout 4 Not Using 8gbs if Ram As The System Requirements Says..
Sebastian_7
14
Hey Guys can you help me... Fallout 4 Is just Using ROUGHLY 1.5 - 2gbs OF Damn RAM i saw it in task Manager... Im Angry at this... Its not using more than that.... I Saw the person on youtube who has the same Processor, Graphics Card, and Ram As Me (https://www.youtube.com/watch?v=2T4vSRKXfEk) He Seems to Be Running Fallout 4 At Fine 45 FPS.. Well I Run it At 10-20 FPS... 15 Being Average fps And 20 being Max FPS.... Well Please Help Me.....
Intel i3-4150
Geforce Palit GT 730
8gb Ram DDR3 Memory...
I Have A 64-BIT Windows..
I Ran it At The Lowest Settings though.. Still 10-20 Fps..
You know that both your CPU AND GPU are below the minimun requirement for Fallout4??? Dont you??? Not the recommended requirement, the MINIMUM!!! What are you expecting??? 60FPS...? Considering that both are Under minimum requirement, 20FPS is not that bad!!! If you want more, youll need to upgrade my friend!!!
I Didnt Expect 60 fps man.. Expected 30fps to 45 fps... And Dude Come Down... Your Not having the problem... I Am...
https://www.youtube.com/watch?v=2T4vSRKXfEk He Has Same System As Me.. Same Build... But He Can Run It At 45fps With medium Settings His Game runs 5gb of Ram... (As Seen On His top left screen in the video..)... But I Only Run it at 10-20 fps at The Lowest Settings possible... And It Only uses 2gb Of Ram..
Yeah the Youtube video is using the gddr5 version, because he details the actual build he used in another video:
https://youtu.be/hEpOIKQOjGs?t=1m23s
I suspect OP has a GDDR3 version, which is a very significant performance loss.
Also the Youtuber is recording a video, that's pretty ram heavy.
