Fan adapter question
coohjay
51
I'm looking to have 5 case fans in my case and they're all going to use 4 pin or 3 pin connectors. My motherboard doesn't have enough connectors so I'm looking to invest in adapters. http://www.memoryexpress.com/Products/MX5153 This is the adapter I'm planning on buying.
Now I was wondering if I could buy 4 of these adapters, and plug the first one into the second one (3 x 3 pin), then the second one into the third one, then third to fourth, leaving me with 5 3-pin connectors that I could connect all my fans to. I want to do this instead of buying a fan controller.
Now, would there be any power lost? because if I kept connecting the cables together would the current get weaker and weaker each time? Would putting the 3-pin female on the 4-pin (and vice versa) male be bad? what would it limit? Thanks to anyone who replies
"Now, would there be any power lost? because if I kept connecting the cables together would the current get weaker and weaker each time?"
technically, adding more fans will draw more power. If you draw more power from a connector than the connector can handle, it will damage the motherboard.
"Would putting the 3-pin female on the 4-pin (and vice versa) male be bad? "
No. The 4th pin is for speed control. A 3 pin fan will just run normally on a 4 pin socket. A 3 pin socket will not be able to control the speed of a 4 pin fan.
So what should I do? buy one of those cables, then buy multiple molex to 3-pin connectors so I can connect that to my power supply? Then connect that to exhaust because it will always be running at full rpm?
But would what I proposed still work? " buy one of those cables, then buy multiple molex to 3-pin connectors so I can connect that to my power supply? "
