Fan and Case Clearance
MikeChung07
In my upcoming build I will be using the Phanteks P400 Tempered Glass. I will also have two 140mm NZXT Aer RGB fans on the top of the case, but I've heard it is very tight when it comes to clearance on the top. Do you guys think the fans will fit? (There is also a Enermax ETS T40 which is a 160mm CPU air cooler in the build.)
I saw a pic of an Enermax fitting in a S340 elite and other cpu cooler , with 162mm fitting in a Phanteks p400, so i think it would fit. Good Luck! , p400 its a good case.
It says that it's 161.7mm but I know case manufacturers make their clearance larger compared to what they tell you. But do you really think it won't fit in the P400?
