Fan anti-vibration solution
Hi
I have bought a new case and the Corsair SP140mm at the back of the pc is making the grill rattle, where do i get some kind of rubber screw or washers to stop this darn rattling.
It rattles when the edges of the fan are in contact with the case.
Thanks
________________
Check a hardware store, I keep a variety package of them around, can pick them up and most any regular HomeDepot or hardware store
Most quality fans either have rubber feet or come with rubber mounting plugs. But if the problem is something with the case then you should make sure everything is secured properly.
You could check performancepcs or frozencpu form fan mounting gromits.
________________
