Fan blocked by its own wire
MDG
42
I did a build last night with an Intel I5 processor using the fan that came with it. When I powered on, the fan didn't turn, and I immediately hit the off switch, and checked everything. Tried again and it still didn't come on, till I flicked it with my finger.
Figured that maybe current MBs didn't turn the fan on right away, so I let it go till it hit 90 degrees at which point I used my fingers and it burst into action hitting 1000+ RPM and being very noisy until the temp dropped.
Eventually I realized the the fan wire, which is anchored in a circle, was barely touching the fan blade at one point- enough to stop it starting, but not enough to stop it once it was spinning ... and also the cause of the extra noise.
I had to play around tugging enough slack out of the circle of wire to make a safe separation.
It seems this is a manufacturing defect.
It probably was, but if the cooler isn't in exactly the right position it's easy to make a mistake. I would glue the wire where it was supposed to go so it can run semi-permanently. if you don't have glue hanging around in your house then I guess it wouldn't be as far away as the PC store.
Return it if you want, but I think you're probably better off just getting a cheap aftermarket cooler for $25. Even the cheapest ones run cooler than stock fans.
Usually in the past I've put on higher quality aftermarket fans that are often a pan to install,with convuluted clips, this was deceptively easy, just push until 4 posts engaged.
It was packaged with the CPU, probably not worth the gas to get a new fan only. I would have thought the wire was put on by a machine
Thanks - that's a great idea, I have some gap filling industrial "crazy glue"at hand, but maybe silicon caulk is better as it can be undone later if required. But then I'd have to caulk the bathtub to justify opening a tube, and I'm feeling lazy
