N nikola.tosic65 Prominent Aug 23, 2017 3 0 510 Sep 13, 2017 #1 Hello, I've put Fan on front of my case but cable (4pin) is too short to reach mobo, So can i somehow use molex from psu instead without any adapters? Thanks ahead.
Solution S S Sedivy Sep 13, 2017 I wouldn't use molex because then your fan is stuck at max speed at all times and that can get annoyingly loud when you're on idle. Instead, just get an extension cable, they're super cheap: https://www.amazon.ca/Startech-Com-Power-Extension-Cable-M-FAN4EXT12/dp/B0058DN7B8?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B0058DN7B8 and that was in canadian dollars so even cheaper on american amazon. Or you can just get it from a local computer store, avoid shipping charges.
S Sedivy Estimable Dec 17, 2016 2,315 0 3,960 Sep 13, 2017 Solution #2 I wouldn't use molex because then your fan is stuck at max speed at all times and that can get annoyingly loud when you're on idle. Instead, just get an extension cable, they're super cheap: https://www.amazon.ca/Startech-Com-Power-Extension-Cable-M-FAN4EXT12/dp/B0058DN7B8?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B0058DN7B8 and that was in canadian dollars so even cheaper on american amazon. Or you can just get it from a local computer store, avoid shipping charges. Upvote 0 Downvote Solution
