Specs:
14900K
360mm AIO mounted at the top of the case (exhaust)
Corsair 7000D airflow - notice that this case has dust filters on the front and side opening ... So I should probably get high static pressure fans ? (does it even matter?)
( I am looking at PWM ARGB fans)
I have two options:
1- Buy 4 high quality / high CFM / high static pressure 140mm fans and put 3x in the front(intake) and 1x at the back (exhaust), and make them spin faster and do NOT install any fans at the side opening.
2- Buy 4 cheaper 140mm fans and install them like (1) + 4 cheaper 120mm fans, install them at the side opening(all 4 intake) and make them spin slower.
How would YOU buy case fans for this setup ?
14900K
I have two options:
