[SOLVED] Fan Configuration Advice - 4000D Airflow
Drerunsit
57
4
18,535
Hello, everyone. For reference, please see my current build here: https://pcpartpicker.com/list/F44mTn (Note: Arc A750 is not installed yet; waiting for it to arrive this week, so it currently has an RX 580 in it)
I have 3x 120mm fans in the front, 1x in the back, and 1x on top (exhaust). Picture here: View: https://imgur.com/a/tVRgfki
What I want to know is if it is worth putting another 120mm next to the other one on the top (exhaust, obviously). Not being an expert on the subject, I just assumed that if I placed one there, it would immediately exhaust the cool air coming in from the front (since the fan would be closer to the front of the case than the components). Am I correct in this assumption? Thanks in advance.
What I want to know is if it is worth putting another 120mm next to the other one on the top (exhaust, obviously). Not being an expert on the subject, I just assumed that if I placed one there, it would immediately exhaust the cool air coming in from the front (since it the fan would be closer to the front of the case than the components). Am I correct in...
What I want to know is if it is worth putting another 120mm next to the other one on the top (exhaust, obviously). Not being an expert on the subject, I just assumed that if I placed one there, it would immediately exhaust the cool air coming in from the front (since it the fan would be closer to the front of the case than the components). Am I correct in this assumption? Thanks in advance.
Hi.
Yes, you are correct.
