Fan configuration for silence
Corbetio
54
I have a be quiet shadow rock slim in a zalman z9 case which runs pretty loud when I play games. It is currently facing up toward the top fan which I believe is outake as I never changed it. Should I rotate the cpu fan to face a different way and would this be quieter? Thanks
Most of the time you're hearing the bearings of the fan moving around, and not the air flow, so it is doubtful this would reduce noise.
I built a FreeNAS box with 13 x 140mm fans in it, and the tower is virtually silent because the fans don't ever spin at full speed.
