Fan configuration help
savedsoul83
5
I have a Cooler Master HAF case. I was looking for some input on how I should sweet up the fans I currently have. So, I have two Corsair sp120 high performance fans, the two stock 120 fans that came with the case, and a H75 corsair liquid cooler that has two fans on it. The stock case fans supposedly have 54cfm ands the sp have 63cfm. Atm I have one Sp on the front top port as intake, with the cage for additional drives removed so the air is blown directly into the case. Below that SP fan I have one of the stock cooler Master fans blowing into the case, but directly into the HDD & SSD. The other stock cooler Master fan is mounted as an intake on the side of the case, and the other Corsair SP fan is mounted on the top as an exhaust. The two fans that came with the H75 are mounted on the back of the case with the radiator inbetween them in a push pull config. I dont know the cfm of those two fans. So basically I can move any of those fans anywhere, would it be better to put the high performance fans on the radiator and move the radiator fans elsewhere? Put both the high performance on the front as intake, or just leave it all alone.
Is the system currently getting too hot?
If no, leave it alone.
If yes, move some fans around. It may get worse, it may get better.
If it gets worse, change it again
If it gets better, leave it alone.
