Fan configuration with 2 radiators
yassterday
22
hey guys, so i need some help on configuring my fan placements, i have a arctic accelero II gpu cooler which i want to mount on the back of the case and a h100i which will go at the top, how would i configure the fans? have the fans all intake ?? i got a obsidian 750D ive also changed the fasn to corsair sp120's and 140's all my case fans will be corsairs fans, thanks
For the radiators positioned that way, I would set them both to exhausts. With both your CPU and GPU being watercooled, there won't be too much case heat to worry about, and temps would be almost identical (maybe a degree or two higher as exhausts). This will keep the overall airflow better and more natural, and make sure to keep the warm air passing through the radiators out of the inside of the case.
oh yeak and would it matter on what side of the radiator i put it on ? push or pull?
Not really, but for much easier cleaning if you have the fans between the radiator and case exhausting air, it's massively easier to clean dust build up
oh thanks, i dont think dust is a problem, where i live, i mean ive had my current pc for about 2 years now, and there is very very very little dust, thanks for your answers you have greatly helped me!! :)
