Hello everyone, first i have to say i'm a noob and my english is garbage.
Well here's my issue, i've made an update to my setup a new graphic card and a new cooling system for the CPU.
System specs:
* i7 3370 ivy bridge
*Mother micro-atx MSI H77MA-G43 (2 sys_fan)
*Deepcool captain 120
*Rx 480 8gb
*Case Raidmax Hyperion
2x top Fan (120mm) exhaust
1x front Fan (200mm) intake
1x bottom Fan (120mm) intake for the gpu
1x back Fan (120mm) exahaust for the liquid cooling -connects to the cpu_fan header-
The problem is the new liquid cooling need 1 sys_fan for the pump. And I need to connect the other 4 Fans.
I was thinking to buy 2 splitters:
____ 1 splitter for sys_fan #1: Connect 2x top fans, 1x front fan. And make them work with the temp of the CPU
____ 1 splitter for sys_fan #2: connect 1x bottom fan and the pump. make the fan work with the Gpu temp and the pump not because it connects only with 3 pins so the controll doesen't affect it.
¿Am I right doing it like this? or is there another way because i'm affraid to screw the pump.
Help pls
System specs:
*Rx 480 8gb
Help pls
