I'm about to build my first system, and I know nothing about fan control; googling Guides/Tutorials didn't help much, so please help me. I want to swap the stock fans, and populate other positions, with alternate fans.
1.
The manual of my case (Thermaltake Core V71) says
"Fan speed and light controller are only compatible with built in 200mm LED fans. To avoid on damaging the circuit board, please do not connect it with other fans."
Does this mean that I'll be using a separate fan-controller to control all my chosen fans (including those I replace the stock ones with), and that the case's fan controller and buttons must be useless to me?
2.
I've started looking at fan controllers.
Would it be a bad idea to (and can one?) use some kind of adapter to connect more than one fan to the same connection on a fan controller?
1.
2.
