Fan control on Gigabyte Z87-UD3H
Zz_Bloody_zZ
20
So I have a UD3H MB. System fan 1,2&3 are 4 pin connectors, however I can not find any corsair fan which has 4 pin, so I have to go ahead with 3 AF fan which only have 3pin.
I go in BIOS setup and surprisingly, those 3 fans on system 1,2&3 system fan slot can still be controlled by adjusting PWM value (I tested, they still work although they only have 3 pin).
So I set them to 2.5 PWM/degree (highest). But, there are still a little not fast enough. The other 2 option is "Normal" , "silent" and "full speed" . Normal is 2.0 PWM/degree, Silent spin extremely slow, Full speed means spin at maximum speed all the time, no control.
Is there any program that can be applied here for this MB to control those fan in window 7 64bit? I tried Easytune but after install, there is no option named: smartfans 🙁
🙁 I see that the MB itself can control those fans. I think there must be a software as a solution for this. is there anything about easytune that I don't know? I have searched some easytune review, all other people can control their fans from gigabyte easytune, they have a function named SmartFans which I can not see in my Easytune :|
What version of easy tune do you use ? I have ET6 but it's very bad and only 2 levels for fan temp and rpm range. And rpm won't stay at the level it must be
