If heat is a problem, I'd use a hw device to control your fan speeds .. a lot easier - you can get them for about 20-40 USD.
Make sure you have the proper fan installs - ie not too many fans that just swirl hot air all around your case instead of a good flow of cool air from front and hot air out the back.
