I own a Asrock J4205, which has two 3-Pin interfaces for the fan control.
The whole system is getting quite hot and is a bit tight with the SSD inside, I therefore bought a Fractal Node 304. This NAS case has larger fans with 4 pins. What is the best way to connect the 4 pin fans to the 3 pin motherboard?
I have found Noctua NA-FC1, but I am not sure if thats suitable. And there are quite expensive, so that I could also sell my old board and buy a new one with 4 pin probably.
