Not sure if this is the best place to ask this, so feel free to move it if it's not.
I'm using a fan controller to control three fans (2x 80mm, 1x 120mm all LED). I've plugged it into the PSU directly because I'm concerned it could overpower and burn out the MOBO fan connector. But I'd like to be able to monitor the RPM's.
So my question is, would it work to plug it in to both the PSU and the MOBO? Would one just cancel the other out or could it create problems?
Sorry if this is a stupid question but thanks for helping anyway.
Oh, I should probably tell you what my system is:
Foxconn A7GM-S Mobo
AMD XP 64 6000+ 3.1 ghz duo core
Broadway (Okia) 600W power supply
MSI Radeon HD 4670 (installing next week)
4GB DDR2 800
Seagate 750GB 7200rpm SATA HDD
WD 1TB 7200rpm SATA HDD (installing next week)
LiteOn BluRay player
Pioneer DVDRW
Generic manual fan controller
Generic Card reader
Generic PCI wireless g card
2x 80mm LED Case fans
1 Logisys 20mm LED CF120BL Case Fan
That's probably more info than you need. Thanks for the help.
Foxconn A7GM-S Mobo
4GB DDR2 800
Pioneer DVDRW
Generic Card reader
