G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking (More info?)
I just got and installed the Zalman 6 channel fan controller. 2 of the
channels are controlled using 3 position switches [off, 5v, 12v]
Obviously I can run my cathode tubes through this, but I just wanted to
check; i'd wire the tubes directly into the fan controller right ?
cutting off the black box ? Im assuming the fan controller takes on the
role of the black box. This is the first time ive started to mod things
so i just wanna double check incase i screw summink up 😛
thx
Genex
thx
Genex
