hi everyone I'm looking to get myself a NZXT sentry 2 fan controller.
It has 5 channels rated at 10w per channel.
will this fan controller be enough to handle my 3 200mm fans, a 120mm fan and a 140 mm fan in my HAF X case?
also, I found the sunbeamtech rheobus extreme with 6 channels at 30w each. Is this a bit overkill for my set up? I only plan to tap a single fan for each connector.
200mm fan:
Rated Voltage -- 12 VDC
Current (Ampere) -- 0.16 A (Max 0.28 A)
Power consumption -- 3.36 W
120mm
fanVoltage -- 12VDC
Current (Ampere) -- 0.35A
Input (Watt) -- 4.2W
140mm
Voltage -- 12VDC
Current (Ampere) -- 0.08A
Input (Watt) -- 0.96W
any tips on what to look out for in finding a controller would be great too.
200mm fan:
120mm
fanVoltage -- 12VDC
140mm
Voltage -- 12VDC
