Fan curve for RX 580 Nitro+ Special Edition
scherioyt
41
Hey guys, I recently bought a Sapphire rx 580 nitro+ special edition and the max temperature I reached is 78°C on fortnite.
Is there a fan curve that allows my gpu to reach less temperatures? Thanks!
You can make one yourself with a program like MSI afterburner. It will give you a graph, you can set the fans to run at whatever percentage you want at a certain temp. So you could make fans run at 100% when the GPU reaches 70c, or whatever you want.
In msi afterburner it shows 79° max when i do hours of gaming and on screen most of the times I see 75-77 ° while playing
So is this temp okay. I have this same gpu rx580 8gb special edition. Also I don't want want to do anything manually because it runs at 300mhz and fans dont work when idle and uses less power. When gaming it works at 1430 mhz and fans start so don't want to change this automation.
