Fan Display Help And More
EpiphanyOfMusic1
New Case with built in Fan Controller Front Panel Display
FanController has
(4) 3 Pin Connectors.
(1) Molex Male, Daisy Chain Female
I connect my Fans to the respected (4) 3pin connectors
And the Molex to my Power Supply
Turn on computer and they light up but after 20 seconds Fans stop going.
I ended up buying a 3pin to Molex Adapter. Connected that to the Daisy Chain Molex of the front panel. Works fine
Why won't the (4) 3pin connectors on the front panel Power the Fans on their own?
Also it has this one cable I can't identify. It looks like a copper tuning fork with a clear plastic tube around it.
I would also like to Add it comes with (2) USB 5 Pin that when I connect to my USB 1 and 2 does not work either.
I ended up connecting them both to a single 9 pin (5top,4bottom) USB socket on my MB
And it just says unable to recognize USB device
