I am planning to use the fan below on my next build and have some questions about fan header current.
http://www.coolermaster.com/cooling/case-fan/masterfan-pro-120-ap-rgb/
Under specifications, I see that the rated current is 0.16A and that the safety current is 0.3A. I take this to mean that the maximum it will ever run at (including startup) 0.3A.
Given that a single fan header on my mobo is capable of supplying 1A, I should theoretically be able to run three fans (0.9A) off of a single fan header safely. Is this line of reasoning correct?
