Fan Header Issue
LiquidFlame
102
Last night when I was messing around with my rig, I noticed that one of my fans wasn't running right. At startup it would run fine, but after 30sec or so before windows would load, the fan would just stop. I had it plugged into the chassis fan #1 and at first I thought that the fan might have died. So I plugged the fan into chassis fan #2 and it worked fine, so I knew it wasn’t the fan. I started to worry that I might have actually shorted out the chassis fan #1 header, so I tested another fan on that header and the same result. I then decided to go into the BIOS and look at the fans settings thinking it might have something to do with that. I changed the “Chassis Fan” setting to manual, which made the chassis fans run at 100%. I restarted the computer and bingo the fan that is hooked up to chassis fan #1 works fine, so I figured it was the setting in the BIOS. My question is, is this really an issue, I know I should probably not have it running on 100%, but I just don’t understand why the chassis fan #1 doesn’t run when in the BIOS it’s set to SmartFan. Also I had question about the AUX fan header. Right now my 8800GTX blocks it from view, I am able to hook up a fan to it, but I was wondering if any one new if the 8800GTX sits right on top of it or not. It looks like a tight fit and I want to make sure nothing is getting cracked or bent. Any help would be great. Thanks for the advice in advanced.
Personally I set all my fans to run at a minimum of 80% constantly and 100% if things get even mildly warm. Yes I will burn through fans quicker but they are cheap to replace vs. fried hardware. Running it at 100% shouldnt give you any issues.
By the way I have a 680i, but I just find it wired that under the SmartFan in the BIOS the fan doesn't work on the chassis fan #1, but does on chassis fan #2 and as far as I can tell under the SmartFan, both are controlled be the same setting. Does this sound like there's something wrong with my board?
Could be, but I would suspect its bios related not hardware malfunction/damage. If the system is running stable and you arent experiencing any other issues, youre probably goo. You could try updating the bios if you are really concerned about it.
BIOS is up to date, some one in another forum said it sounded like a classic fan undervolt. When I get home from work, I'm going to try and reproduce it under the manual settings to see what's going on.
Possibly some voltage fluctuations to #1 is causing under volts to the fans. Do they make a splitter to run off #2 so both fans can run in smart mode?
