Fan headers incompatible with fans?
dankest_bank
25
I have two case fans which are connected together to create a single fan header. I try to connect it the the 4 pin port in my motherboard but no matter with what angle I put it in it is loose/won’t connect.
My motherboard: Asrock x370 pro4
Fans: the 2 included in the P400S
The fan header has 2 holes and 2 pins next to it, while the port on my motherboard has 4 pins.
http://
http://
So where would that be? Is it on the motherboard, or?
