I've been running into a problem with my motherboard (or possibly PSU) recently where 2 out of the top 3 headers do not seem to be supplying sufficient power to any fans. I am wondering why this would suddenly happen out of the blue..
I am running separate AIO coolers on my CPU and GPU - my CPU is being cooled by an NZXT Kraken X52, with the pump plugged into the W_Pump header, and the two fans (intake) attached to the radiator plugged into the CPU_FAN and CPU_EXT headers.
My GPU is cooled by a Corsair H55, attached by the NZXT G12 bracket. Both the fan (intake) and the pump are connected to the fan power provided with my case.
I also have one additional fan (exhaust) connected to the H_AMP header on my motherboard.
Everything was working perfectly for around 5-6 months. CPU was averaging around 28c idle, 38c load. GPU was similar - 30c idle, 40c load. This is all at around 22c ambient.
Just last week, I saw my CPU temps climbing without anything going on. At idle, it was slowly ramping up until it hit about 80c and I decided to shut down the system and investigate.
I noticed on next startup, that the two front radiator fans for the CPU stopped working. They would twitch a bit, but not spin at all. I was able to confirm through NZXT software that the pump was still running, however.
I tried swapping different fans into those headers - every fan would exhibit the same behavior. Slight movement every so often, but would not spin.
For the meantime, I've moved those two fans to my case fan connectors, though I am seeing a hit in performance from it. Maybe I'm being paranoid, but I also believe I am seeing my GPU hit higher temps since this issue. It now regularly hits 70c in games, and even higher in something like Furmark.
Is this likely an issue with my Motherboard? Or is my PSU struggling to deliver the power to my fans? Something else?
Would an internal fan controller be my best bet if I didn't want to replace any major components?
My build is:
Motherboard: MSI X99-A II
PSU: Corsair RMX 850w
CPU: i7-6800k (OC to 4.0ghz)
CPU Cooler: NZXT Kraken X52 w/ stock fans
GPU: GTX 1080ti
GPU Cooler: Corsair H55 w/ stock fan
I also typically didn't use any software to control my fans - I would let NZXT CAM control my CPU pump everything else just run on whatever stock curves were present.
Thank you for your time, and sorry for the wall of text.
My build is:
GPU: GTX 1080ti
