Fan help with new build
noahsheldon
71
http://pcpartpicker.com/p/Ms2ZmG Is my build I currently have. I will be doing video editing on it which will be fairly CPU intensive and kind of GPU intensive although not as much. The case comes with one 200mm fan in the front and a 140mm fan in the rear. The fans it comes with are okay but nothing special. I was wondering though should I get a 140mm top fan and 140mm bottom fan for underneath the power supply? Also, which is more important, get two extra fans or get an extra fan for my Noctua cpu cooler?
Thanks
Honestly, I don't think there is any need to get such a big case. If you decide to go with that case, the fans it already has is more than enough.
If you got with an ATX mid tower. The Fractel Design R5 is a great looking case with nice features.
