I'm in need of some help.
I require 8 fans for my build but my board only has 6 fan header, so i've decided to get this fan hub: http://www.amazon.com/SilverStone-Technology-All-Black-CPF04/dp/B00VNW556I/ref=cm_cr_pr_product_top?ie=UTF8
My cpu cooler will be a noctua nhd15 which has 2 fans.
My question is, since I cant plug in both fans into the cpu fan header can i plug in the the main lead from the fan hub into the cpu fan header and then plug in my two cpu fans into the hub and use it that way, will it still work fine?
