Hi!
I bought an Id-cooling FH-07 fan hub, and for the first few days it worked perfectly. Yesterday my PC crashed (I was using CEMU and it stopped working, apparently a common issue) and after resetting, the fans are stuck at 100% all the time, extremely noisy.
Fans are 3x Id-cooling Tf-12025 plus the one that came with the case (a 3-pin fan). Motherboard is Gigabyte B450M DS3H V2.
What should I do?
Thanks!!
What should I do?
Thanks!!
