Fan hub with control?
warren997374
41
Looking to build a mid budget pc, and the motherboard that i got my eye on doesn't have enough fan headers, i've seen fan hubs but apparently they set fan speed to max and give you no control. And i've seen spliters which im not sure if you can control the second fan or both fans are controlled at once.
So my question is, is there a hub out there that gives control over fan speed or is spliter the way to go? and how are fans controlled over spliters? and can spliters power 2 fan reliably? or better suggest a better <matx board.
Full build https://uk.pcpartpicker.com/list/ds4Nw6
Similar threads
