[SOLVED] Fan installation?!
May 27, 2020
25
I have 4 3pin preinstalled deepcool fans. Each fan will be plugged into a the motherboard as the board has 3 sys fans. I will use a 4pin spliter for the last header. But where does the rgb connect. I thought I had a 5v rgb connect but don't. I do have a 12volt connector can I plug it into there. I also have a vdg cable and port can that be used?
Thanks.
Thanks.
5v connection is for ARGB lights and 12v is for RGB lights, they are not interchangeable, You need some kind of ARGB controller for them.
