[SOLVED] Fan issue Asus Aura and Cooler master fans
jacob68
Notable
Jan 30, 2019
188
14
815
I just bought and installed 3 x Cooler Master MF Pro 140 AP.
According to Asus these are Aura compatible (I have a TUF B-360 Plus)
Fans spin up nicely when booting.
Lights up fine all 3 during boot.
When I get into Win10 the color turns off. But the fans keep on spinning. Que?
I have 1 RGB header. So they are connected via a 1-4 splitter.
Aura wont recognize them.
Any clues?
Ps. My LED strip connected to the same splitter works fine and can be controlled by Aura.
Solved. But leaving the post here as a ressource. Its Asus AI suite that <<Inappropriate language removed by moderator>> it up. Uninstalled all Asus software. Installed only Aura. And then it works.
Installed AI suite and it works.
Ran autotuning in Fanxpert+ and boom the lights went off...
jacob68
Notable
Jan 30, 2019
188
14
815
Pps. Tried reversing the fans connection to the rgb splitter suspecting wrong marking. No result. Also, all fans are nicely detected and adjustable in BIOS. And as mentioned in the beginning, they only "die" when in Win10. In BIOS for example they are nicely lit...
jacob68
Notable
Jan 30, 2019
188
14
815
