I have a case I bought I would say about 10 or 11 years ago. I know it is an Antec something. It has one fan up top with a "spolier" a fan in the back, a fan in the front, and the power bay is in the bottom. For the life of me I am not certain which case it is. I updated a bunch of stuff a few years back, and these days the fans do not spin as they should. I for the life of me cannot recall if they worked correctly after the original update but I did add in a new Nvidia GForce GTX 1080 about a year ago. I am concerned that either the fans. being old have worn and need to be replaced, or that the addition of the new graphics card might be too much for the power supply I bought a few years back to run everything. I am hoping someone has a suggestion of a way to be certain. Also, I am hoping maybe someone will recognize the case, since I am not certain what size fans this box is using. The power supply is a EVGA Supernova NEX750B.
Found the case. It is a Antec P182 Gun Metal Black which has 120 mm fans. Is it likely these have just worn out or is it possible my power supply is insufficient?
Thank you for any help you can offer.
Update I found a cooler master power supply calculator and did my best to fill that out and it recommends I have at least 618 W power supply. The one I have is a 750 if I am correct. So is it likely that my fans are simply worn out from 10 years of use?
