Fan Issue
Chaos Water
56
I've got this strange issue with my case fans, when my computer boots onto the desktop for a split second all my fans slow right down then speed back up again.
Here's all my case fans I have at the moment if this helps
4 Arctic F12 120MM (2 intake/2 exhaust)
1 CiT LED 120MM (intake)
1 Coolermaster 120MM (exhaust)
1 Coolermaster 120MM LED (intake)
If it helps here are my system specifications
OS - Windows 7 Ultimate 64bit
CPU - AMD FX 8150 3.6GHz (AM3)
GPU - Sapphire Radeon HD 6850 1GB + XFX Radeon 6850 1GB (Crossfire)
RAM - 4 X 2GB Kingston HyperX Blu DDR3
PSU - Coolermaster GX650W
Case - Coolermaster CM690 II Lite
Monitor - Acer 23" HD 1080 3D LED Monitor
Keyboard + Mouse - Aula (Chinese make)
Is this normal or is there something not right?
Do you have any software that controls the fan rpms. Like Speedfan, or an overclocking utility if so it might be the program taking control of the fans. Probably nothing to worry about.
