I am a newbie and could use advice. This build is for 3D work. I'm going to be adding a second GPU, same kind.
https://pcpartpicker.com/user/renderphire/saved/CWgJf7
I'm planning to put the Kraken X62 in the front of the P600s case. The case comes with two 140mm fans installed in the front and one 140mm fan in the rear.
I'm considering adding two 140mm fans for a push pull configuration in the front. Would this mean I should remove the included front two P600s fans?
What considerations should I make for the top of the case? Or would no fans be better?
Report Edit Delete Follow comments
