Hi everyone,
I am planning on a major upgrade. My only question is the airflow inside the case. I did my research and found positive and negative pressure, i am gunning for negative to lessen the dust from comming in. So to achieve this i need more intake fan than the exhaust. Knowing this the problem arise, where should i place my fans.
Case fan location:
Front (bottom) - 2 x 120-140mm
Rear - 1 x 120mm
Top - 2 x 120mm
Scenenario 1: 3 x 120mm static pressure intake (2 on top and 1 at the back) and 2 x 140mm airflow exhaust. Basic science states that hot air goes up, so i am a concerned if the exhaust will blow the hot air out from its position (lower front panel). And my HSF btw will blow air to the front as well, will my RAM suffer due to the excess heat blown toward them?
Scenario 2: 2 x 140mm front and 1 x 120mm rear static pressure intakes while the top is 2 x 120mm airflow exhaust. The problem here is where will my HSF blow the hot air from the procie? To the front?
Scenario 3: 2 x 140mm static pressure intake, top and rear are 3 x 120mm also static pressure exhaust with a lower rpm. HSF towards the rear exhaust.
Which scenario will hinder dust from comming in and expel hot air out effectively.
Thanks guys.
Case fan location:
Rear - 1 x 120mm
Top - 2 x 120mm
Thanks guys.
