Fan locations in a 360mm Radiator? [Custom case problem]
DatGameh
110
Hello, and thanks for coming.
The problem I face is right in the title...
I want to create a mount for future plans if I want a 360mm radiator, so I need specific dimensions.
But first, I need to know how far each fan is from each other within a 360mm or a 240mm radiator (any radiator with 120mm fans)
I know for one thing that they are not right next to each other. There is some distance between them, but I can't find the exact dimensions.
Does anyone know?
Actually, as seen here in this one Corsair example, which is the very first one that came up when I googled the images to verify what I was already pretty sure of, they are. Directly against each other that is. I really doubt it matters though. I believe I've seen models where they are together, as these are, and others where there IS a space and they are more oriented to be positioned towards the edges of the radiator. Really the spacing is going to be determined by the hole spacing of the particular radiator. They are unlikely to all be the same.
Alright then, so instead of fan distance, my concern is now the hole distance.
But... All radiators follow a format, which allows them to be compatible with any case.
Do you know the distance between the holes?
