fan making weird noise on cold startup
iron_3
Commendable
Jan 25, 2017
4
so i recently got a new pc on christmas and the front lower fan makes some werid sound when it starts up at first its fine then the windows loading circle comes up and it goes slow it doesnst stop till im at the desktop i usually restart my pc the same day and its normal i can restart it has many times that day and it will be fine only the next day on a cold startup does it make this noise
Strictly speaking it will not effect the system as long as the fan keeps spinning.
but you should replace the fan, due to the worn bearing of it as if it fails the fan will cease to spin causing an overheat of the cpu in your system if found as the one making the noise.
