So I just built my first AIO based system in the Be Quiet Pure Base 500 Window with the Silent loop 2. The AIO is cooling a R5 3600 and I have a Zotac Amp Extreme 980ti (it's massive).
Which way round should I have my AIO fans? Currently they are intaking air from inside the case, pushing it through the rad and then into the front case panel vents.
Problem is, because my GPU is so massive, the 2nd AIO fan is like half an inch away from the end of the GPU heatsink. Also, the tempered glass side panel is warming up during gaming, not so it's hot to touch, but it's warm. All the CPU and GPU temps are fine.
My other fans have 2 intakes on the top and 1 out take at the back. Would it be better to have the AIO fans intake from the front of the case and then push all the hot air into the case and out of the back. Although then the second fan would be pushing hot air directly on to the GPU heatsink...
Any help is appreciated!
