Hi all, this question is very specific to the ThermalTake Core G21 which has been reviwed at Tom's Harware. If you are looking for a video review, its here : https://www.youtube.com/watch?v=82bJwkRmh70&t=275s. It can take either 3 120 mm or 2 140 mm intake fans.
I noticed that with the front cover off, the case frame has 3 slots, seperated by metal strips which would be great for the 3 120 mm fans.
It also fits 2 140 mm fans, but am, worried as to how they would fit. Would the 3 metal strips imped airflow and create turbulence ? Am I worrying about nothing ?
Hope someone has some advice as I do like the case and am planning on hopefully getting it.
Thanks ....
Thanks ....
