hi i was wondering which setup is better? my case is lancool ii mesh pro. i might add a fan on the bottom blowing air up depend if i have space.
View: https://imgur.com/a/2QHmCBN
It's not even that bad, especially if the front intake liquid cooler is on the cpu.if the front fan blowing in wont it blowing in hot air from the radiator?
Yes, that would be a good arrangement. Which rad goes where may not matter, and maybe you don't have a choice when you see the lengths of the hoses and pump placements. IF you have freedom to choose, look closely at the specs of the fans on each system. Try placing the system with higher max air flow as the front intake.
Yes, for front intake mounting.
my gpu and cpu will be water cooled so thats why i have two rad. so you guys recommend me front fan intake and back and top fan exhuast?
That's a good arrangement. Just a note as you assemble. On every fan on the outside of the frame there usually are two arrows. One points around the fan to show the direction of rotation. The other points through the fan to show air flow direction. Make sure the front fans are mounted to blow the air through the rad.
Yes, you should have dust filters in front of the front intake rad fans. Your case may already have such filters built into its front panel, so check carefully.
Right - direction of air flow is the only important thing.
The web page for that case says in its specs (at bottom) that it comes with two magnetic dust filters, one each for front and top.
Dust Filters | 1 x Top (magnetic), 1 x Bottom (tray) |
