CPU: 9700K
MB: Aorus Z390 Elite
PSU: EVGA 850 GQ
I'm using the darkFlash TR240 AIO which has those aura/led connector from the pump that should plug onto motherboard.
This may sound weird but I've tested everything one by one untill I found out the D_LED2 header on board was causing all this. If I leave it plugged in. Rear fan, led and psu fan stays on but everything went off immediately after I unplugged.
Btw, rear fan and the led both are plugged into the hub that came with the case (NZXT H440 without PWM) and only those I've mentioned stays on. The pump or the opt fan on radiator were off.
Any idea how to fix this even with D_LED2 plugged? Have already tried CMOS reset. Fast boot, hibernate and everything related were turned off.
Here's the issue (video clip)
PSU: EVGA 850 GQ
