Fan Recomendations Please
sami5991
28
Can anyone recommend any good, cheap PC case fans. If they use low power then so much the better.
They must be 4 pin fans, I want one that is 92mm and one that is 80mm.
Also I don't want to spend over £5 for each of them, so £10 is the budget.
One will be for the side of the PC to intake air while the other will be for the back to exhaust the air.
Thanks in advance.
Can I ask why 4 pin fans and not 3 pin?
