I am trying to install 3 Noctual NF-P12 fans. Cyberpower built my PC and I am nervous whenever I open this thing up.
Main Goal: replace the 2 fans connected to my water cooling system. I just now got the original fans off.
First question: Both fans were installed by Cyberpower in the same direction (facing inward toward radiator). Should I just do the same? I thought I've seen people say one should point in and one out (push/pull) or am I misunderstanding all that?
Second question: Have a 3rd fan to put in. Was thinking I'd do the rear fan. Is there another one that would be more important (as this fan is an upgrade to all of them)?
Problem is, my rear fan has it's power cord disappear under the Mobo, and I have no idea where that thing goes to. Am I wrong, or is there no way to really see what's happening in that area behind the mobo?
Thanks!
Thanks!
