Hi,
I am just wondering how I can remove the stock fans and put something much quieter on there?
The fan under load is loud. The specs I find are 34db idle and 40 under load:
http://hexus.net/tech/reviews/graphics/37009-sapphire-radeon-hd-7970-oc-dual-x-3gb/?page=10
Since this is not a reference designed card is there any aftermarket cooler I can use, or is it possible to replace these fans with much quieter fans?
